Originally Posted by
Bob Pastorello
...getting to 28% expo makes the movement of the control surface actually "linear", that is, the percentage of control movement will match the amount of stick movement, proportionally.
This isn't a magic function...it is simple rotational geometry of radial movement against a linear goal.
I disagree. Given a somewhat symmetrical geometry, there is no need for expo...the system is proportional...20% movement of the stick moves the servo 20%, which moves the control surface 20%. 80% movement of the stick moves the servo 80% which moves the control surface 80%. The motion is rotary-translational-rotary, resulting in a linear and proportional output. The SIN function is working on both sides of the pushrod.
Kurt
