Originally Posted by
Panther F
IF you do not mind one more opinion... I use "Ultra Lube" sold in a tube at Lowes hardware stores.
Works for me as I have used ALL of the grease marketed in the past because my field of expertise was that of an ASE Certified Auto Technician.
Jeff
Opinions are good. They educate and identify options.
Namerifrats
Marc780, I noticed all those wheel weights on your tank. Debated adding a little weight myself. Did you do it for more realistic appearance with the suspension flexing, or better climbing ability? Wonder if it would have any negative effects on the motor life with an extra pound or two added.
I've put weights into some tanks to balance front and rear, particularly on the rear drive tanks. This helps with traction, especially on hills. The added weight will put more strain on the motors and drain the battery faster. The other advantage to heavier tanks is that they crawl through the grass better when backyard driving. That said, heavy tanks lose responsiveness faster when in IR battles.
