RCU Forums - View Single Post - Thunder Tiger Trainer 40 project
Old 04-26-2015 | 04:26 AM
  #186
Calvinman
Hi allModes, it looks like, judging by the length of the pushrods that the nose gear rod crosses over to where the rudder pushrod joins. Sometimes the nose gear steering goes on the same side as the rudder(on the servo arm) sometimes not. the first thing you will want to do is to hook the rudder up to the servo and sort out which side it should be on, then figure out which side the nose wheel will have to be on to steer correctly.
