RCU Forums - View Single Post - Another Drone Pilot does it Again
Old 04-26-2015 | 07:06 AM
  #1089
franklin_m's Avatar
franklin_m
Originally Posted by bradpaul
My question is concerning the full scale, if the drone was 200' below the airliner is 1200' AGL a usual altitude when 3 to 4 miles from the runway?
Actually, not unusual at all. I've attached two images, one is a standard 3 degree glideslope and the corresponding AGL altitudes by mile. I've also attached an excerpt from an IFR approach showing that at 5.8 miles the aircraft has already descended to 1500 MSL. Since the touchdown point is 44 MSL, I'm guessing he starts the approach at around 1450 AGL about 5 miles or so from the field. So to be at 1200' at 4 or 3 would bevery reasonable.
While I’m sure many know this, for those that don’t, here’s how to calculate aworst case a 3 degree cone around any airport: take the distance from the airport in nautical miles (that's what airplanes use) multiplied 6076 (feet/nm) multiplied by the sine of 3 degrees. Using that calculation, an airplane at 3nm on a perfect three degree glideslope could be as low as 954 feet (note: excel’s sine function requires the angle to be in Radians – in that case, the calculation is (nautical miles x 6076) x sine (3 x 3.14/180). What you'll see is that even as far as five miles away, airplanes on instrument approaches could be as low as 1590 feet AGL, well within capabilities of many quads and RC planes.
Most real world approaches bump up the altitudes up a bit from a perfect 3degrees, but that’s a worst case. Oh, if someone asks why not use tangent of the angle, the reason is that mileage measurement in the airplane on a VOR/DME or TACAN approach is line of sight from the airplane - so sine makes for a more precise calculation.
Honestly, many quite small airports have instrument approaches, which is why I'm personally a fan of limiting RC ops to 400' AGL. I know that's not popular, but from a risk management standpoint, it keeps them away from the overwhelming majority of full scale operations and vastly reduces the risk to the traveling public.
Name:	Approach Excerpt.jpg
ID:	2092243   Click image for larger version
Name:	AGL vs DME.jpg
Last edited by franklin_m; 04-26-2015 at 07:13 AM. Reason: fix missing spaces between words
