One of the reasons that comes to mind is that the thicker, heavier props used for nitro or gas engines produce a flywheel effect that tends to keep the engines running at idle especially in the four stroke engines that only fire on every other revolution. That is not necessary on electric motors. But they are YOUR props. They can be interchanged if you want to.
