Originally Posted by
BarracudaHockey
Sure.
The gyro works by the signal on the gain channel, how you get it there is up to you. On my Habu I have more gain when the gear is down because the speed will be lower and the gain can be higher.
That would be great !! But my problem is between my ears... I'm not seeing it. How do I get there ? In the gain channel you have Zero ( off ) and two gain choices.. How do I get that to the flap switch and will that eliminate the " Off " choice. Your cutting, but I ain't bleeding... Beat the hell out me with the knowledge stick !!!
I'm using JR12x if that is any comes into play...
Thanks !!
Danno
