RCU Forums - View Single Post - Xicoy CG machine delivery update.
Old 04-30-2015 | 07:51 PM
Len's Avatar
Len
As far as I can see the trailing link issue makes no difference to the CG machine. The point at which the wheel/tire touches the transducer is the projected point of support of the airframe. In other words it is the supporting position of the transducer that matters not what it supports. To take this to the absurd you could put a solid trailing link 3 feet long behind the plane and still the point where the transducer supports that trailing link becomes the measuring position. This is all about moment arms, not just the weights measured. To simplify: if you have the main wheels' axles 2" behind the strut center then you would measure the length to the CG, nose wheel support point (axle), and weight addition positions, from the 2" behind the main strut position. I hope this helps...
Len
