Robert,
Thanks, luck is always a welcome friend.
Hopefully I did my homework well. Time will tell
Thanks , David
But would never consider giving Robert a run.
It's guys like him that gave me the courage to build this big.
It's guys like him that make me want to be a better modeler.
Spent the morning sanding and polishing.
Sanded both plugs to 1000 wet.
Then used a product called Finesse-it 2 and an electric buffer.
Use the Finesse-it cause that's what our finishers at work use.
Had 2 goals,
Not to burn thru
And to achieve a Class A finish on the plugs.
Did not burn thru, and probably ended up with a class A- or B+.
But I am happy that it will make a fine surface to mold to. Yea !!!!!! no more sanding
Kevin
