Simple answer, when running all you see is a spinning disk, so fly it on the best 2 blade for the engine, and for display put the 4 blade on. Probably not the answer you are looking for, but unless you know how to make gears, and build a reduction drive, 3:1, the 4 blade will never get the plane off the ground.
