I have little more work ,the pull pull must be readjust + I have problem with the battery placing ,the reciver it's right up by the main gear wheel I was short on Chanel's so I did one matchbox for the rudder and stering + I haved little fire the turbine was setup with way to much fuel startup so the fuel was all ower the flor and all get o fire
only quick action safe the jet from inferno all is good now so maybe the maiden flight next weekend ,Jim will you please post picture where it's the cg on your gripen just from the side view for preference comparing to my cg mark thanks .
