He said he's running two 2s packs.
Check your receiver's antenna and make sure that's in tact. If your not sure, try testing it with an ohm meter. Are the batteries in the transmitter good? ESC/motor plugged in correctly? Does the steering servo cut out at the same time the motor does?
Originally Posted by
EXT2Rob
You don't have the Lipo LVC (low-voltage cutoff) engaged and are running NiMh batteries, are you? That would do it.
