Originally Posted by
grbaker
You can't turn much rpm for very long with the stock rod in a .77. I have bent a couple of them in Byron fans that don't turn as many rpm as they do in the Dynamax.
Another trick with the OS.77 is that you can run a back plate and carb from an OS.91VRDF on the .77. Works very well!!!
Yup the stock rod is bushed I machine my own titainium rod with a needle bearing on the crank end works well as long as the piston pin boss hangs in there, don't ask me how I know .....ha ha........
