RCU Forums - View Single Post - Powerbox Igyro 1e
Old 05-08-2015 | 03:10 AM
gunradd's Avatar
gunradd
My Feedback: (9)
Use it in rate mode. Also you want to disable the gyro by using the gain so that when you are in flight its not trying to move your nose gear. Even if you disable nose steering in the transmitter if your gyro gain is left on it will still try and move the nose gear and burn the servo out. So make sure you put a mix on the gear switch to take gyro gain to 0.
Originally Posted by viggkri
Hi
I am bringing an old Kangaroo back too life, i am planning on using Igyro 1e on the nosewheel too assist me on takeoff. This plane has no rudders.
Which mode do i use, and can i leave it "on" all the time?
Viggo
