RE: GWS E Starter
Yes in stock trim the e-starter is a great trainer. Can fly slow and speeds up quite well. The roll rate with the ailerons is super slow so if you decide to try to roll it make sure you have plenty of altitude. The stock power set up is very good. It will also handle a little wind better than most of the gws birds. Would I buy another one? Yes! If you get one do a search and look at the building tips because there are a few week spots on the airframe, mainly the tail section. Good Luck.
