RCU Forums - View Single Post - Top Flite GS P-47 sports scale; diary of a build
Thread
05-09-2015, 03:33 AM
2080
TonyBuilder
My Feedback: (
11
1 Post
Main Gear
The main gear is completed, both sides have working doors.
Once I have the air hooked up I will do final trimming.
They are not perfectly matched but close enough. When I do the Miester I will do the doors first making two identical sets then cut them in.
The gap is a little bigger on the left wing and I will make the right to match as I don't want any binding issues.
The inner doors are adjustable as to the throw on the open position and once I am ready to install them for good I will set them equally.
The gear is set so it is flat to the wing when the doors are closed and the wheel is inside. This gives the wheels a slight toe in. If I want to change that I would have to sand the gear strut to change the angle but I don't think I will do that on this build, a little toe in cant hurt.
TB
Reply
Like
TonyBuilder
View Public Profile
Send a private message to TonyBuilder
Find More Posts by TonyBuilder
View iTrader Profile
