Originally Posted by
Gray Beard
Just a thought but have you taken the muffler to a welding shop? As I recall the pipes were just brazed in. I have broken pipes off of aluminum mufflers and had them repaired for a couple bucks.
Before I buy a new one I may just try and braze the broken on back on. There is a suspicious brass ball inside the muffler, near the pipes, as if it had been repaired before. If I totally fail then a new muffler is only $35.00.
I'll clean up the broken one a bit as see what I have. Not damaged too bad.
SunDevilPilot
