Hey Gary,
Got the glass cutout of the wheel well for the gear install with the gear mounted as far forward per your recommendation. Looks to fit nicely if I adjust the axle so that it is not flush with the gear leg. About 1/4" sticks out which I expect I will cut off. Do you know what bag contains the gear mounting hardware? I don't really see hardware that matches, looks like I should be providing my own as all of the bags seem to be labeled for other uses. Do you have recommendations for screw lengths, looks like countersinking the forward inner screw would provide the best clearance for the permanent covers. Do you see any issues with this?
John
