RCU Forums - View Single Post - Rc ignition kill switch setup
Old 05-11-2015 | 02:15 AM
jadec241
My Feedback: (29)
Default Rc ignition kill switch setup
Am running a DLE20cc gas engine in a stick. Usually I run a 2000 Mah. battery to a on/off switch & then to the receiver for my servos & a 2000 Mah. battery to a on off switch for the ignition. I ordered a opti kill switch for my ignition. I would like to run a single 6 volt battery using the gear switch on my transmitter to kill the engine & also the battery to turn the servos on
& off. Directions will come with the kill switch but would appreciate it if someone could explain the setup.
