RCU Forums - View Single Post - Rc ignition kill switch setup
Old 05-11-2015 | 05:49 AM
BarracudaHockey's Avatar
BarracudaHockey
A kill switch plugs into the gear channel (or any channel that you assign a switch) on your receiver.
For the ignition, you run from the battery, to a switch, to the kill switch to the ignition.
If you want to power the ignition from the receiver there's a way to do so but it requires a modification as outlined in the manual that comes with the kill switch.
