Lormhul...
Great response. After seeing your initial post I did some research on these wraps and sounds like you're testing is accurate. I was also concerned that the wrap might block some air movement over the lower cooling vanes on the heads. but doesn't seem like that's a factor. I'm definitely going to give it try.
