I didn't check to see if the checkerboard was that funky adhesive stuff, I just assumed. Freebird, I got the1/7th scale radial (it's a Top Flite item). I've looked at many renditions of Bevo's plane and on most there are no reg numbers on the top wing, so either way works! What are you guys using for power? I decided to go electric as to not have to butcher up the cowl. Will probably change the wheels as well.
Bullseye52
