RCU Forums - View Single Post - sullivan battery box
Old 05-14-2015 | 05:07 PM
Gray Beard
My Feedback: (-1)
Originally Posted by jetmech05
The type of battery is up to you. Get whatever type you can easily charge. Voltage and size is what matters. 12 volts for the starter then the panel step down to 1.5 volts for the glow plug.
I used to use a rechargeable glow stick and a car jump starter for the starter. The 12 volt sealed batteries I used were only good for about a year
I used to do what Jet is describing but went to the simple button a few years back. I haven't seen the new Sullivan item your asking about but simple is better. I just use a Harbor Freight 18 volt battery attached to my starter, no long wires to worry about, a glow stick for the glow plugs and a hand crank fuel pump. Less is better.
