Originally Posted by
SrTelemaster150
Seldom will the needle setting that worked on the test stand be exactly the same as when the engine is mounted in the airframe. Especially if the engine is mounted in a different orientation as far as vertical/inverted.
My settings on the test stand never require changing once in the airplane, but I NEVER have an inverted mounting anymore. Been there, done that, did not enjoy.
