Originally Posted by
CH Ignitions
Also make gap on the spark plug .35mm, go and try up to a 36btdc.
Adrian
Thanks Adrian.
I did not know of these potential issues with the rcxel tachometers. I will try the engine without it and set the gap on 0,35mm and play with the timining as you and Dan suggest. What is strange, though, is in your video on FA-125a you have set the timing at 30 degrees BTDC and the engine runs brilliantly. Now in the video this is with 15% nitro. In case you tested the engine with 5% nitro or straight fuel how did the engine idle?
-Artto
