RCU Forums - View Single Post - Reverse propellers and pusher setup - Teksumo wing
Old 05-17-2015 | 06:30 PM
tacx's Avatar
tacx
ALL props must face the same way. Towards the front of the plane. Irregardless if they are on the rear or front of the plane. A pusher props blades have the opposite angle than a standard ( or tractor ) props blades.
The reason for a pusher props is for when they are used with reverse mounted glow engines that can only run in one direction. For example, a swamp buggy with a rear facing glow engine. For electric planes you do not need a pusher prop because you can mount a standard prop facing forward and reverse the motor if needed.
