If the Campac is not formatted, and the transmitters is seeing it, then it will ask you if you want to format it. If it's not seen by the transmitter, then you won't be able to access it or format it. You may have a bad Campac or something wrong in the transmitter. We'd need to see both to determine where the difficulty may be.
