Rusted has the experience with the lipo's, I'm still running Nimh and brushed motors. The SCX10 is probably what you're looking for, and other than suspension and link options, all the SCX10's are basically the same chassis set-up. The Deadbolt is the name of the body that comes with it. If you've been to Axial's website, you'll see that there are actually 9 different ways to buy the SCX10, with 3 of them being kits. The Dingo kit is the least expensive, and has the most basic suspension set-up on it, and as with all kits, you'll have to supply the electronics/batteries. It also has the shortest wheelbase, however, by changing the location of the shock towers, you can lengthen the wheelbase if you decide to run with a longer aftermarket body.
