After seeing and experiencing several in flight throttle servo failures, these days I recommend a throttle servo of the same quality you would consider adequate for any of your flight surfaces. I consider resolution very important on the throttle and you don't get that with a cheap servo. Certainly we expect the servo to be reliable. That said, yes you can get good throttle response with most any servo.
