RCU Forums - View Single Post - retract switch push rod...
Old 10-15-2003 | 01:06 PM
IFR
Default RE: retract switch push rod...
I used a standard push rod and mini clevis, the kind used on electric planes, and put a z bend on the servo end. The Spring Air valve requires very little effort to move it. You can also drill the hole in the valve arm to accept a standard clevis.
