Originally Posted by
Hobbsy
Pete, I never use on board glow power, I never saw the need for it. I tried it once so long ago that the on board system was built by ACE RC in Higginsville, Mo. I had a mechanical switch that you slid the actuator for or aft to set the energize point. I have the correct pipes coming.
PS, please say something about my new OS .56 or my feelins will be hurt.
I have a servo plugged into the throttle channel to manually activate the on board glo with the 182 twin at low speeds,if i still had it tuned the way it was i would'nt need it but that's what can happen if you are not comfortable with bloody airbleed carbs x 2 on the same engine.I'm getting used to it.OK i'm clairvoint (sp?) and predict that in an upcoming post someone called jenny will mention your os 56 although i don't know if she's related to sarah two dad's
