RCU Forums - View Single Post - Another Drone Pilot does it Again
Old 05-20-2015 | 10:20 PM
  #1368
Rob2160's Avatar
Rob2160
Originally Posted by Sport_Pilot
Not news to me. These engines are tested with birds that are much larger than a 5 pound sUAV and they keep going.
Tell that to Sullenberger..
It sounds good in theory and I wish it were true in all cases but facts prove otherwise - foreign object ingestion can and does cause engine failures.
The FAA certification standard for a large bird strike (above 1.85Kg - 4.07lbs) in a turbine engine does not require the engine to continue producing power.
It only requires the damage to be contained within the engine and not result in further damage to the aircraft / airframe.
http://rgl.faa.gov/Regulatory_and_Gu.../ac33.76-1.pdf
Even forgetting about the engines, impact damage anywhere on the airframe can also result in a crash e.g. the Concorde - which was brought down by a 10lb piece of rubber hitting the wing.
Name:	Screen Shot 2015-05-21 at 4.13.42 PM.png
