Originally Posted by
HarryC
Can anyone suggest a solution to this problem? When I switch on the model, the wheels go up, then come back down again. I am using a CB200 with an electronic valve (not jetronic) for the retracts. I have 2 of the same valves for retracts and doors in another model with an R12 rx and that has no problem. The problem is because of the time delay between the CB200 passing power to the outputs, and eventually generating a servo signal. Many analogue servos, and this valve, move a lot when just given power and no signal. I can't swop the valve outputs and reverse the servo/valve because it is spring loaded to one output and the down is on that so that it remains pressurised down when the radio is off. I have tried with no failsafe set, and with failsafe set to wheels down, it makes no difference.
Do not have any pressure in your air tank until after the radio is turned on.
