Thank u both
@luv2flyrc. Powerbox has a xbus port and a telemetry port. Xbus is for powerbox data(and data from other sensors) and the telemetry port is for connecting to the tm1000 to get flight recorder data.
@andy. Powerbox has support for flight log data. The current setup works fine if I don't have the xicoy module connected. I can power up the system and read 0s for all flight recorder data and read out proper battery capacity. I can turn off the tx and watch the flight log data on the power box start to increment on all values. I can then turn the tx back on and the incrementing stops. The values on the powerbox flight data matches what is reported on the tx. When I put the xicoy module in the flight data doesn't work as described above.
It would be disappointing if this combo doesn't work as with the popularity of kingtech turbines this should be a popular combo
