Originally Posted by
HarryC
Can anyone suggest a solution to this problem? When I switch on the model, the wheels go up, then come back down again. I am using a CB200 with an electronic valve (not jetronic) for the retracts. I have 2 of the same valves for retracts and doors in another model with an R12 rx and that has no problem. The problem is because of the time delay between the CB200 passing power to the outputs, and eventually generating a servo signal. Many analogue servos, and this valve, move a lot when just given power and no signal. I can't swop the valve outputs and reverse the servo/valve because it is spring loaded to one output and the down is on that so that it remains pressurised down when the radio is off. I have tried with no failsafe set, and with failsafe set to wheels down, it makes no difference.
Harry,
You mentioned that you've tested it with no fail-safe set and with fail-safe set to wheels down. When you say "no fail-safe set" does that mean you've disabled fail-safe altogether, it's set to HOLD or that fail-safe for the gear channel is set it to OUT-OFF?
Also, which valve it is that you are using?
Wayne
