RCU Forums - View Single Post - Hen Leong Pershing M26 RC Tank has a mind of it's own! Can't control it?
Old 05-21-2015 | 11:38 PM
kizwan's Avatar
kizwan
I can't quite see the wires in the pic but if you traced the wires for the 8-pin, even when the plugs swapped, the pins on the daughter board on the upper hull will always connect to the same pins on the RX18.
