Originally Posted by
Jack Diaz
HarryC, I'm not familiar with that radio, but try binding the receivers with the gear switch in the down position (and also in the up position), and see if it makes any difference.
If it was Spektrum or JR, it would.
Jack
It's nothing to do with the radio settings, nor is it specifically a Jeti problem I have seen it on other brands. Old fashioned rx did not have a boot up time and passed the data signal to servos almost instantly after power came on. Rx with microprocessors have a definite boot up time so the servos get power but no position signal for the first second or two. As a rule of thumb, digi servos stay still but many analogue servos will turn a long way when they get that initial burst of power but no data. I would get the same problem if I used an analogue servo and a servo operated valve. This electronic valve is behaving like an analogue servo. I think the only way around it is to try a different brand of valve.
