Again, page 166 details operation of the TIMER and how to set a switch to turn it on or off.
Bax, It appears that you and McXtreme are looking at different veraons of the manual. The PDF that I have, Doc #1M23N27902 has the Switch Setting Method on page 166 and the Timer functions on page 165
If I understand correctly, the Switch Setting Page CANNOT be accessed when you say, assign a servo to do whatever to channel say, 8 using the
Linkage Menu>Function page. The Switch Setting Page is ONLY available when you access the switch assignments via the
Model Menu>Prog. Mix page. Is this correct?
My next question would be, WHY???????? I want to do this:
1. Set air brakes CLOSED when switch SD is UP.
2. Set and tail hook to retracted when switch SD is UP -OR- MIDDLE.
3. Set air brakes OPEN when switch SD is MIDDLE -OR- DOWN.
4. Set tail hook DOWN when switch SD is DOWN.
Seems pretty straight forward to me. Switch UP, air brakes closed and tail hook retracted. Switch MIDDLE, air brakes open and tail hook retracted. Switch DOWN, air brakes open and tail hook extended.
Is there some way that I can do this? If not, is the firmware available to me so I can make the modifications to allow this? All the mixes in the
Model Menu>Prog. Mix page seem to be assigned at the factory. Pretty much makes them useless to me. I'd really like to be able to use the whole radio.
Just asking'.
