Could happen to ANY radio at ANY time. No battles needed. Well, Its not much, but i got all of the skins glued up for the fuse bottom and sheeted the forward fuse bottom this morning. Ive checked and re checked everything to make sure im not missing anything before i close up the tail. Good to go. I also replaced the rear side stringers with 1/4 x 1/4 aspen as to avoid extra blocking for the tail wheel doors. I actually weighed the two sticks before gluing them in and there was no weight gain from the balsa sticks. What are you guys hinging the TW doors with? Piano hinges?
