RCU Forums - View Single Post - First gas engine question
Old 05-29-2015 | 08:34 AM
  #36
dirtybird
Originally Posted by av8tor1977
I often run mine on a test stand to get the engine dialed in on the mixtures and verify that it runs well. Maybe half a tank to a tank of fuel, with no sustained high rpms. Then I mount it on the airplane and fly it. Flying is the best way to load and unload the engine, heat cycle it, and break it in. No hovering for the first several tanks in order to help keep the engine cool.
AV8TOR
I disagree. When flying you have no way to know what the engine is experiencing if you dont have telemetry that includes temperature,RPM and load.Even if you do the chances are it will be too late to do anything about it.
With a good instrumented test stand you have much better control.
