You need to follow the instructions right to the end doing everything in the order called for I know the bind plug must be removed but I think you need to shut your transmitter off too then restart everything . I have Spektrum and I find it very easy to bind but as I say you need to follow the instructions all the way . Plus as has been pointed out you should have your Tx a few ft away
