Originally Posted by
sparky4lawndart
answers...
it was running great - it was starting easily by hand... WOT @ 4,000 RPM with 2 out on the high needle and 6 out on the low needle (set with the throttle closed) very rich - a lot of black oil coming out of the motor
cylinder temps - 185 degrees cylinder two, 195 degrees cylinder 1, and 205 degrees cylinder 3 - all F with a digital laser temp gauge on the top of the cylinder
exhaust - no "pooling" that I could see/hear... started by hand
crankcase vent - no tube or blockage
Frank, I am out of ideas... seems like something different then.
One last thing I can think of is that the manual says to go over all bolts after the first tanks to check for looseness. Maybe that cylinder had a loose one and the remaining lugs on the bottom could not take the stress...?
Anyhow - good luck on your warranty. They will ask you to send the motor in and after disassembly it will show whether it was a hydro lock or seizure or (hopefully) a material failure.. Let us know - for the benefit of the thread.
BR,
Hector.
