RCU Forums - View Single Post - DLE-30 Experts HELP
Old 06-02-2015 | 05:06 AM
sea157
My Feedback: (30)
Originally Posted by irocbsa
Yes, you can turn it 180 degrees. Make sure the gasket is oriented correctly so the pressure pulse port for the pump is not covered up otherwise you'll never get it to run.
With this turned 180 degrees and the pulse port open it will run just as good, no known other problems?
