RCU Forums - View Single Post - Spektrum remote receivers
Old 06-02-2015 | 06:32 AM
tp777fo's Avatar
tp777fo
My Feedback: (28)
Default Spektrum remote receivers
my new FB Dolphin has tons of CF in the fuselage. The numbers on my data logger were not real pretty with a couple of satellite RXs in the 500-600+ fades range. As bad as that looked there were O frame losses or holds. Spektrum says over 500 should be fixed but with the amount of carbon there isn't anywhere to move remotes to avoid it. Anyone using the satellite RXs for CF fuselages? Do the help? Can you mix them with regular satellites? Anyone using satellite leads over 3 ft? Thanks!
