Thanks Gray Beard, by the looks of the structure and T.M. pics on the net I felt the Premire kit was the closet, with a 67" span, and I am usually wrong so I am not positive of the make. With the stab at 0 deg I have a top wing at -6 and the bottom at - 2 which I did not like. The Great Planes .60 size ARF has the same dimensions you gave, 0 stab and bottom wing and top wing minus 2. Which I like, although the Flair Moth specs are stab + 1.5, top wing = 1.7 and bottom wing at + 3 deg. A little different. This plane is built so in a few hours I will go out and re-shape the fuse wing cutout to get the lower wing at 0 along with the stab. I think the struts could be part of the problem, all 4 are the same length with the wing being a clark y the aft struts should be longer. Thank you very much for the information, John.
