Originally Posted by
Len Todd
I put telemetry in all my gas planes. My first plane (existing and later put in telemetry) was running over 300 degrees F and I was able to get that down to 230 with baffles and more air outlets. Most of mine run about 225 - 250 give or take ambient air temps. Also, I use the telemetry RPM readings in the air to figure the best prop that gets the engine in the power band. There is quite a bit of difference between running on the ground and in the air. RPMs also help tune for that slightly rich sweet spot. But you can get a hand tach too for that.
Len what're you using to obtain the RPM figures in the air? Are you piping it back to your receiver through some sort of optical RPM gauge, or through the ignition...?
