Im having the same problem with my trophy flux buggy! can you pop it so it does? btw if thats not it try setting your trim to the middle and remove the servo arm from the servo then turn the remote and car on then put the servo arm back on in the middle so you do not have not to adjust the trim. if thats not it then its the hub carriers
