Originally Posted by
woodie
I have heard of one other Olympus with a similar issue. I recommend contacting the dealer you bought it from for resolution. I don't think you could effectively heat/twist the foam so it would take a new set without melting the foam in the process.
Woodie
Thanks for your reply Woodie. Here are three photos that show what the fuselage twist looks like. You can clearly see that the horizontal stab is not parallel with the wings (the gap between wing and stab on each side) and if you look closely enough you can see that the tail leans the same direction as the horizontal stab. So do other Olympus airplane fuselages have a similar twist like this or is my fuselage something I should complain about to the dealer or manufacturer?
