RAV, I got you on the "+" for the Master allowing the trim function for the slave. When I enter into the Prog MIX 1 I can set my Master as RUDD, (which is my nose wheel) but when I click on the slave my options do not include AUX6. Instead, it reads "RDVT" where AUX 6 should be. When I tried AUX7 instead of AUX6, the space that should have AUX7 then switched to "RDVT". What AUX are you using for your rudder ???
thx...
Bill
