Hi Harris, with those LADO retracts you should be OK, they work very well on mine! What I did do is to connect them to my receiver via a Y-cable. Before I had them on seperate channels on the receiver.
Never figured out why but it happened to me that after retracting one leg was up and the other still down!! Very bad situation. Then when I put the retracts down one went down.... and the other went up! Still only only leg out. Then I switched a couple of times with the result that both were out! Coming in for the landing one went up again! Disaster. In the end I was able to time the landing in such a way that I touched down just when both were out. Hairy experience! So use a Y-cable.
Volkert
