guff you can use heavier shock oil in front say 55 wt and 45 wt in rear as temperature changes gets hotter you can use even heavier oil, and you
can change springs too , you also want the buggy to sit level side to side and front to back , next is diff oil since you bashing through grass , dirt
etc you do not want a heavy of diff oil use 7000 front 5000 center , 5 000 rear , or 5 -5- 5 some guys for racing use 5-5-3 depending on track
the dirt , loose or hard clay jumps and turns , there's a lot of variables for the buggys , truggys nitro and electric also check what the manuals recommend ok hope i helped
Reason: forgot center oil
